Author Topic: Speedometer  (Read 2257 times)
Offline MILO851
Speedometer
« on: January 31, 2019, 09:32:55 AM »
Hi I own a 1999 super last year after riding 20 miles or so I would lose the speedometer. It would quit working  it ran ok but would sometimes come and go . it would randomly?start working then quit again  any ideas? Ground? where? Thanks Larrt
Re: Speedometer
« Reply #1 on: January 31, 2019, 12:49:58 PM »
Do the other gauges still work? Tachometer? Fuel gauge? No other lights coming on or going?
I had the road speed sensor go bad on one of my bikes. It would display normally, then drop to zero for a few miles, then work again. Ultimately that was the sensor.
You have to drop the exhaust and dig into the faux oil tank on the right side of the bike to replace it. Once all that’s off there’s one screw and one plug to swap it out.
With that said: I don’t know if you have any other history with the bike like rodent or fire damage to the harness. Obviously: those should be looked at first. If the harness looks good, the sensor is a likely culprit.
Offline MILO851
Re: Speedometer
« Reply #2 on: January 31, 2019, 02:39:25 PM »
I cant remember if tack worked . I think so  I will look at better in spring just wanted heads up  any source for sensor or is specific to eh
Re: Speedometer
« Reply #3 on: February 01, 2019, 09:25:12 AM »
The same sensor might be used on some other motorcycles but Atlantic Excelsior Henderson should have it and you know it’ll be the right one.
