Author Topic: 1999 Super X S/N 61  (Read 1429 times)
Offline Ed Petrow
1999 Super X S/N 61
« on: January 22, 2024, 10:17:21 AM »
1999 Super X S/N 61
1999 Excelsior-Henderson Super X
Black with Red Pinstripes
VIN:  5EH1HCX07XB000061
Original and Current Miles:  9,650
Serial number 61 is one of about 1,650 built between 1999 and 2000 and was manufactured during the initial production run but was never assembled or delivered to the early investor who was assigned the serial number.  Instead, it was purchased new by the current owner from an authorized Excelsior-Henderson dealer in 1999 with every accessory available at the time including windshield, soft saddle bags, extended shift lever and driving lights.  The owner has all promotional material, service records, keys, books, accessories and spare parts including the rare service manual that was unfortunately, never completed before the company folded.  Even the door of the shipping crate is included that still has the signatures of most of the Excelsior-Henderson staff at the time.
Over the past the past 24 years of enthusiast ownership, this original example has been extensively serviced and updated by Jamie Jones of Super X Service in Elkton, VA.  Jamie has rebuilt the engine and updated the notoriously poor shifting 5-speed transmission by blueprinting the rotating components and installing premium parts.  Among other updates, he has replaced the troublesome wiring harness, updated the ECU with the latest software and replaced the fuel tank, pump and pressure regulator after properly coating the inside.  Wide white wall, tube type tires and a supplemental oil cooler were all installed around 2005.  With a recent oil change, brake signal switch  and new battery, the bike continues to run perfectly and with all the work completed by Jamie over the years, most certainly rides and drives better than new.
Many parts have been re-chromed by Jamie or by Librandis Plating in Harrisburg, PA around 2005.  Often the early production Super X bikes were two-tone, but this is a rare black on black example.   It is believed that the fuel tanks and fenders were painted by the individual parts manufacturer and not by Excelsior-Henderson so solid color bikes often had slightly different colors on these three components. To correct this minor variation in appearance, the tank and fenders were expertly painted to the original ?thunder? black with red pin stripes about 2005.  The result is spectacular with many show quality chrome parts and glossy clear-coated deep black paint.  The original motorcycle enthusiast owner is the bike?s only rider and S/N 61 has accumulated just 9600 miles over the past 24 years.  It has always been maintained with synthetic oil changes regularly.  The bike needs nothing and can be ridden immediately although tire replacement is recommended due to age.
This special and well-loved motorcycle is one of several heavyweight cruisers currently owned and for sale by the original owner who has decided to hang up his helmet after a lifetime of riding.  Over the past four years, this bike has probably been ridden a total of less than 20 miles but has always been insured, registered, inspected, and garaged.
More Information
Re: 1999 Super X S/N 61
« Reply #1 on: January 22, 2024, 12:04:40 PM »
Welcome Ed. Sorry to see you signing up and then checking right out. Just to clarify a few points though:
Because of a few bikes hung on the assembly line and some skipped serial numbers, the final count is debated but, I believe we mostly agree at 1,950-ish were made.
Jamie does amazing things but, to call the transmission "notoriously poor shifting" is beyond a bit of a stretch. Some of the transmissions had bronze bearings that were manufactured oversize. SOME of them. The update is to rebush and machine them to minimum size to reduce wobble. The circlips are changed to a better and more expensive design as additional insurance. The shift detent spring is changed to get a little more snap to the shifts.
Raven Black with red stripes is the most common color (680 made) which is more than double the next most common (Green / oyster with silver stripes).
I don't know who believed that but, they were told wrong. I have one of the demo bikes, #26 off the line. It's exactly like 0333. All the tins are buried in very thick, glorious black and deep clear coat finishes. I've confirmed the thickness of the finishes with a coating gauge and they absolutely used the same powder and oven-cure finishing process on both.
Other than that, the bike looks great and I hope it finds a good home.
More Information
« Last Edit: January 22, 2024, 09:38:18 PM by Donkey Hotey »
