Author Topic: fires but wont stay running.  (Read 3047 times)
Offline Tconnell
« on: May 21, 2014, 06:08:00 PM »
I'll try to give the readers digest version...#906 sat most of the last 15 years, with only 2400 miles on it became mine. I rode it from Phoenix to St Paull a few weeks ago.(1800 problem free miles)  I tried to start it a day later and nothing. I got the new fuel lines/filter, air breather element and bracket... fired it up and away I went...until the other day. I rode it about 100 miles, parked it in the garage, gave the Ultra some attention then two days later the X would not start (i've had problems with my x before :) I removed the tank, fuel pump, injectors and lines, cleaned tested and inspected everything. I put it back together and it does the same thing, will fire and run for a few seconds....then nothing. Any ideas out there? Thanks Tim
Re: fires but wont stay running.
« Reply #1 on: June 07, 2014, 04:17:02 PM »
Was battling a similar scenario here in nebraski..... Just recently.
Its just about has to be a fuel issue.
Low miles and stored with fuel.....    Just about promises problems.
Injectors on this one stuck open. Fuel pump was full of garbage. Tank looked good and clean.
Mechanic and owner decided to get new injectors. Didn't clean tank. Pump souned terrible, and it wasn't cleaned out.
Immediately plugged new injectors.
Convinced them to get new injectors, clean out tank and pump. They bought a new pump, and ran some sea foam thru it.
Appears now to running fine.
What i've seen on these crapped up pumps is usually a slimy yellow mess. Appears to be the liner breaking down.... But i don't know that. Even though with a good lite the tank looks clean.
Depending on how old the fuel, ive seen it actually crystalized on the screens.
I also tell all new owners NOT to start their new purchase until its been thoroughly cleaned regarding fuel. It just creates so much more work.
Hope that gives you some ideas...
Sorry for the late answer, but some of these posts get hidden immediately if someone posts something new...
Offline deadwoodsp
« Reply #2 on: June 09, 2014, 11:14:38 AM »
Also check to see if your IAC valve is sticking.  It is on top of thee intake.
Dennis
