April 26, 2026, 01:35:15 PM
Motorcycle Resource Forums
Technical Resource Discussion
Fuel Pump Tank Seal
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Fuel Pump Tank Seal (Read 2353 times)
KC444
XH Rider X
Fuel Pump Tank Seal
on:
August 16, 2018, 09:00:39 AM »
I didn’t know how to remove fuel pump and ended up destroying the tank seal. Any suggestions on what would be the replacement seal to use and where can I find it?
Thanks in advance KC444
Last Edit: August 16, 2018, 09:03:49 AM by KC444
Logged
wytfut
XHRC Rider Moderator
XH Rider XXXXX
What goes around, comes around
Re: Fuel Pump Tank Seal
Reply #1 on:
August 16, 2018, 10:44:26 AM »
Give these folks a call...
They have the "O" ring
superxparts.com
Martie will answer and be able to help you out
Logged
KC444
XH Rider X
Reply #2 on:
August 16, 2018, 04:50:52 PM »
Thanks Bruce. I’ll give them a call.
Logged
blackheart
XH Rider XXXX
0307, Feb 2011, trans, oil cooler, pump drive,bron
Reply #3 on:
September 25, 2018, 07:40:21 PM »
For the record that one is a #229 x type oring. Viton is probably best but buna N surprisingly holds up fairly well
Logged
Print
Pages: [
1
Go Up
« previous
next »
Fuel Pump Tank Seal
