Author Topic: Hazard lights blinking  (Read 2499 times)
Offline Tripindicular
« on: August 20, 2018, 10:20:11 PM »
Hazard lights blinking all the time. Does anyone know what this means?
Re: Hazard lights blinking
« Reply #1 on: August 21, 2018, 09:02:17 AM »
this possibly means your turn signal unit is failing  (mounted on back bone under tank just behind triple tree)...    AND/OR you have a direct short from another "hot" wire.
Hot wire could be anywhere between handle bar controller to the turn signal unti it self....
its going to take a little bit of trouble shooting to find it....
« Last Edit: August 21, 2018, 09:21:44 AM by wytfut »
« Reply #2 on: August 22, 2018, 09:38:08 PM »
Thanks for info
« Reply #3 on: August 26, 2018, 03:13:47 PM »
In other words... You "MAY" be having an electrical issue. I'd suggest that you look over ALL the wiring before you proceed to … Well..  I do knot know of any spare wiring harness's so prevent a melt down of the current Harness, Do the ground wire update and inspect everything else. PRONTO!
