Author Topic: Another grounding question  (Read 2193 times)
« on: December 30, 2018, 03:51:24 PM »
According to the schematics, there are three grounds on our bikes; a chassis ground, engine ground and the voltage regulator, if you want to count that one.
I added a strap from the starter to the frame a while ago, and now want to clean up the connections at the chassis ground under the seat. Looks like the battery grounds to a different location than the chassis electrics. Wondering if these should be moved so they are all in the same location, or should there at least be a cable between them?
Re: Another grounding question
« Reply #1 on: December 30, 2018, 05:45:35 PM »
Yes, there is already a connection between them. That’s the one you’re cleaning / beefing up. The battery cable connects to the top of the aluminum engine cases, directly below that chassis ground you found. The upgrade jumper goes between those two. I guess in really bad cases that wire fails.
In theory, yes, everything would be best at one grounding point. In practice, it would be too many terminals on the same screw. Different guides suggest different numbers on a common screw but three is a pretty standard number. You can get away with four. Any more and the crimps start running into each other.
Yeah, you could add washers between them but washers are usually steel and steel isn’t a good conductor of electricity. You could buy copper or aluminum washers instead but then corrosion enters the picture. All these conflicts are what you have to juggle when deciding how to connect all of it.
The point I’m trying to make is: our bikes share the same grounding strategy as the cars I’ve owned: battery connections to the engine, chassis connections from the engine. If it’s all clean and that jumper is good, everything else is fine.
You bring up a good point about the voltage regulator ground. That actual connection is made on the same screw as the battery cable (on top of the engine cases).
The two issues are simple corrosion from age and the choice of that ground jumper wire being a little flimsy. Are you working that area right now? If you haven’t bought the ground jumper from Atlantic, you might find a suitable one at an auto parts store.
The issue I ran into is they were all just too long. I made my own with some fine stranded 8 or 10 gauge wire I had and a pair of high quality 3M crimp rings. I emphasize the quality part because the rings aren’t flimsy like the ones you might get at Home Depot. The wire wasn’t going to do me any good if the ring connectors failed from vibration. I bought them from McMaster. I also used them to fabricate my own battery connection for my electric gear and battery tender while I was in there.
« Last Edit: December 30, 2018, 05:47:22 PM by Donkey Hotey »
« Reply #2 on: December 30, 2018, 07:26:37 PM »
I had a hand full of 8 gauge telephone grounds with cladded copper ends.
I put one at the starter, and another at the electrical box to eliminate the 2 silly little ones.
Need to note case ground there on most was some more of our friend orange Lok Tite.....  Need to get that removed, as that era Lok Tite don't conduct electricity...
The telephone grounds are very durable, design with weather in mind and to last close to forever...
I put them on several of the X's I worked on thru the years .
