November 22, 2026, 01:57:52 PM
Motorcycle Resource Forums
Technical Resource Discussion
Front axle
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Front axle (Read 1891 times)
Raykav
XH Rider X
Front axle
on:
August 22, 2020, 02:18:55 PM »
Have a damaged thread on the front wheel axle of my super x...anybody know the thread size...?
Thanks
Logged
Donkey Hotey
Bike Hoarder
XHRC Rider Moderator
XH Rider XXXXX
Re: Front axle
Reply #1 on:
August 23, 2020, 02:46:34 PM »
I just tried to measure one of my axle bolts. Everything suggests that it's a 5/8-11 UNC. The issue I ran into is that my cheapo Harbor Freight die is wobbly on the bolt and the tap doesn't screw into the axle either.
The bolt measures 0.613" which is about the right amount under 5/8" (0.625) that I'd expect. For whatever reason, the tap doesn't start easily and I'm not going to mess up the axle trying to go further. It doesn't come close to any common metric size so I'm 99% sure it's not.
The axles and those bolts are plentiful as new-old-stock parts. Berlin Bob had an axle and both bolts for sale on Bookface a day or two ago. I'm sure he has more available.
Logged
since 2000 (Molly)
1989
since 2012 (Jennie)
0333
since 2015 (Beulah)
1663
since 2017 (Deadwood)
0738
since 2018 (Babe)
1940
since 2019 (Sinclair)
1555
since 2022 (Genesis)
0315
since 2022 (Freedom)
blackheart
XH Rider XXXX
0307, Feb 2011, trans, oil cooler, pump drive,bron
Re: Front axle
Reply #2 on:
August 24, 2020, 09:33:08 PM »
It's 5/8-11 unc, I pulled a bolt and ran a nut up on it. Factory used way to much loctite on everything, that should not be necessary. 16 mm x 2 would be a close metric thread, slightly larger but finer pitch by approx 1/64" every thread.
Logged
Donkey Hotey
Bike Hoarder
XH Rider XXXXX
Re: Front axle
Reply #3 on:
August 28, 2020, 06:41:05 PM »
Brand new axle and bolts on Ebay:
https://www.ebay.com/itm/401750327796
Logged
since 2000 (Molly)
1989
since 2012 (Jennie)
0333
since 2015 (Beulah)
1663
0738
since 2018 (Babe)
1940
1555
0315
Print
Pages: [
1
Go Up
« previous
next »
Front axle
