November 22, 2026, 01:31:30 PM
Motorcycle Resource Forums
Technical Resource Discussion
Turn signals & horn
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Turn signals & horn (Read 4469 times)
boomer
boomer
XH Rider X
iamdodgeman54@yahoo.com
Turn signals & horn
on:
May 19, 2013, 12:46:35 AM »
I have #91. It went down on the RH side before I bought it. I began replacing parts starting with the turn signals. So now both of the signal lights on the RH side have been replaced & they work (I tested them). However while the ones on the LH side work perfectly. The RH ones do nothing & the horn doesn't work. I followed wires for 4 hours one night and checked things with a test light. I see nothing obvious. there is no power to the back of the bike. It behaves like something is wrong with the switch, but I see no broken solder or wires in the switch.
Any one have any advice? Where are common places where the wires rub and break coming from the blinker switch?
Logged
99 Super X
boomer
boomer
XH Rider X
Re: Turn signals & horn
Reply #1 on:
May 19, 2013, 06:16:23 AM »
Oh yeh can any one tell me where the turn signal controller is?
Logged
99 Super X
wytfut
XHRC Rider Moderator
XH Rider XXXXX
What goes around, comes around
Reply #2 on:
May 19, 2013, 08:07:59 AM »
The turn signal controller is under the tank towards the front. Box looking item that is zip tied to the frames.
I'm picking up from your limited info, that you may not have a schematic in front of you. I strongly reccomend you get a hold of it.
http://www.excelsiorhenderson.com/pages/tech/pdf/EH_Super_X_Wiring_Schematic_X.pdf
. Heres the link located on this site...
Of the few X's that I've worked on..... I've only seen one where the wires were real tight by the steering shaft under the triple tree. May be worth the look there.
Please let us know if you need more help..
Logged
wytfut
XH Rider XXXXX
Reply #3 on:
May 19, 2013, 08:19:09 AM »
And my best advice until I hear back, would be pull the tank an seat, check ALL the connectors.... Sometimes they look good, but just need to be clicked/pushed.
I'd suspect that with a RH slide some connectors probably got stretched....
Logged
boomer
boomer
XH Rider X
Reply #4 on:
May 19, 2013, 03:58:47 PM »
Thank you I will look at that next.
Logged
99 Super X
XH Rider XXXXX
Reply #5 on:
May 20, 2013, 08:25:45 AM »
Hey Boomer... I sent a reply to your Strut Cap message... If you want to re-post it here, go ahead. Someone may chime in with more advice..
Logged
Print
Pages: [
1
Go Up
« previous
next »
Turn signals & horn
