Author Topic: Engine Removal / Reinstallation  (Read 14178 times)
« on: August 09, 2015, 11:49:46 AM »
1525 gets to have her engine removed.
Here is how she sits right now:
I know I have to remove the electronics cover to pull the sensors and wires hiding under there. Do the front cast mounts stay attached to the engine during removal or do they get in the way? Floorboards (more of that damned thread locker!)?  I don't want to needlessly bust those bolts loose (always an adventure on these bikes).
The front frame mounting cups are off, the rear bolts are out, the exhaust mount is off. It's just not clear to me which side this engine is meant to be removed from. I also assume it has to tilt to clear the opening once the cylinders are back on? There is no other way I can see the cam covers clearing the frame.
Off to Home Depot to buy some foam pipe insulation to wrap this frame. Any tips or a link to engine removal and reinstallation methods would be much appreciated.
Re: Engine Removal / Reinstallation
« Reply #1 on: August 10, 2015, 12:27:04 AM »
OK, engine is out. It was easy with no cylinders. So which side does it go back in? Should the electronics box have been unbolted and removed? I disassembled it as far as I could but the thread locker stopped me again. I'll drill the head off and deal with it if that's how it's supposed to come apart and go back together. I was able to tilt the engine upward and fish it out but, that ain't gonna' fly with the barrels back on.
« Reply #2 on: August 11, 2015, 06:30:30 AM »
Greg,
    So sorry I didn't respond quicker for you....
    but was having window's 10 issues....
    To be honest, I haven't ever taken the engine out of an X....   but have tried to pay attention via www with those who have....
    I was under the impression that removal of the valve covers would be sufficient for clearances...
    I can't answer about the ECU.....   unless there is something obvious that I'm missing...
    First picture is showing the threads out of the case from the head bolts...   correct?  is this the reason you pulled the engine.
    I had this issue on 525.  As you are this far along (I didn't pull my engine).... I strongly advise you to check the depth of those thread bolt holes. My head was leaking due to one of the head bolt holes WAS NOT deep enough for proper seating and sealing.
    So when got the tyme sert kit, we had to drill the whole almost a 1/4" deeper so that the head could   be pulled down correctly. With conversation with Jamie years ago about this same issue..... many X's had that "one" bolt hole not near enough deep.
     I'm also highly recommending Jamie/Marty's head stud kit. Its expensive, but if you ever have to get in there again, it will be much easier.
     I'm also studying closely your process.... apparently the valve covers didn't relief enough room for the engine removal.... and so the heads were removed...
    any/all/more information you share here will be much appreciated. And I'll try and help anyway I can ...
Good Luck Greg!!
« Reply #3 on: August 11, 2015, 09:40:07 AM »
Hey Bruce, your response is valued but, it's not your responsibility to be the answerer of all problems. Thank you. Yes, my hope is to not just get through this but post it so others can find it in the future.
Yes, I already have Atlantic's stud kit. That picture with the threads pulled out is from me test-threading the holes and checking depth. That was the second one and the threads just came out on the stud when I removed it.
It's been disappointing to hear how many clueless people have commented to me in real life about what a POS my bike must be. I guess they never worked on any other sand cast engines. This is insanely common on BMW Airheads, old VWs, etc, etc. I even stumbled onto a specific Harley Time-sert kit that includes all the right length inserts and other tools to do the job for their cases. Spark plug replacement kits, cylinder head kits...so many people who obviously don't work on their own stuff and don't know about the failures. Sad, really. Onward and upward as somebody wrote... :)
Engine installation / Removal:
I can imagine the valve covers would provide extra clearance but, that can't be the way they went in at the factory. That's what I'm looking for: can it be done complete, and if so, how? Now that it's out, it would make sense to bench assemble it and close it out.
I'm going to make some hoisting plates to bolt to the intake ports--ala Chevy engine hoist adapter plate. From that, I can hang the weight of the engine from a cherry picker and just tilt and guide it into the frame with the weight suspended. The frame is already padded with pipe insulation (if you didn't notice) and the engine will get wrapped with a moving blanket as it's bumping into the opening.
Electrical Box:
It wasn't the ECU I was questioning. The entire electronics area is bolted to a couple of plates. It honestly looks to me like if that gets all the bolts taken loose and pushed out of the way or completely removed, the whole engine bay opens up. My guess is that got built after engine installation on the assembly line. I'm not sure if it needs to come out for engine removal or if it's just more convenient that way.
Hole Depths:
I already have an email in to Jamie but, he's a busy guy. If he's not able to respond, it would be nice to know if somebody else has the information.
My main question to him was on hole depths (exactly as you mentioned). I seem to remember reading this somewhere else. The hole you see in the picture? That and one other were over half an inch shallower than the remaining six holes. Based on what you just posted, I wonder if the bolt bottomed out at the factory and ripped those threads loose long ago?
Sitting on top of the bike, the back-right hole on the front jug and the front-left hole on the rear jug are the two shallow ones. Think about where those are: right in the center of the V, my concern and question to Jamie was: is there a reason for them being shallow? Is there no material behind them? An oil galley? I don't want to just go punching a drill into them if there is a good reason they were manufactured that way.
Knowing that the engines were CNC machined, it's hard to imagine a manufacturing process where they'd end up with a couple of random, inconsistent hole depths for no reason at all. I am not getting super precision measurements with a digital caliper just shoved down a hole, yet all the others were consistent: right around 1.64" deep. The two shallow ones were 1.113 and 1.033!
Being manufactured on a CNC, if a drill broke or slipped, creating shallow holes, the following tap would never know and would snap instantly as it hit the bottom. That would scrap the part and it would never make it out that way. That's why I believe those holes were not accidental. Maybe it was unnecessary for the engineer to design it that way, or the CNC programmer to program it that way but, it wasn't an accident. Heck, I've met and talked to the vendor that manufactured our cases and they seemed like a first-rate outfit. That's another story...
Sooo...
  • Is there a reason the holes can't be drilled all the way to 1.64" deep?
  • If not, how deep CAN I go?
The Time-sert website says that you need to select an insert that is 1/4" shorter than the hole depth. That allows some room for the partial threads at the nose of the tap, and a seating area for the locking feature on the insert. 1.64" deep, minus 0.25 = 1.39". The next shorter insert is 1.2" so that's what I selected. I have enough coming to do all eight holes the same but, I also bought two of the 0.870s for the shallow holes (just in case).
The 1.2" inserts need 1.45-1.50 of hole. If it's safe to take the hole that deep, that's what I'll do and all eight will get matching inserts. I'd just like to not experiment on this engine. Somebody out there has to know the answer after all these years.
« Last Edit: August 11, 2015, 09:45:42 AM by Donkey Hotey »
« Reply #4 on: August 12, 2015, 06:37:47 AM »
my bolt hole was ....
as you sit on bike...
rear jug....
top left.....
same place head gasket blew out....
when we went deeper.... we crossed out fingers.... to match the other holes... went very well....
my threads came out when I was cleaning the threads out via running bolts up and down....   about the 4th time....
« Reply #5 on: August 12, 2015, 10:30:27 PM »
Based on both of our bikes being the same location, we can assume it was designed that way for a reason. I don't want to figure out why on MY engine.  :)
After discussion with Jamie, I'm not going to drill any deeper than what's there now.
The tap drill size for the Time-sert kit is 29/64ths. McMaster sells a 29/64ths endmill with a 3/8 (reduced) shank.
On those two shallow holes, I may square up the bottom of the pointed drill hole with that endmill. That will add another 0.136" of usable wall (for threads). I'm going to thread as far as I dare, then trim a couple of longer inserts to custom fit the hole depth. It may mess up the locking feature but, I'm going to red loctite them anyway.
Atlantic's stud kit has 1.17" worth of thread and I want as much of that engaged in material as possible.
Speaking of red loctite: what was the brand and formulation of the thread locker on our bikes? This is one of the few places where I would welcome that level of hold (insert walls). Filling all the voids in the thread will only make the joint stronger. I searched the web but, couldn't find it. I know it's been posted before.
« Reply #6 on: August 13, 2015, 07:12:56 AM »
I was under the Impression it was orange permanet "loc tit brand all these years.
In speaking with Jamie back when my head gasket let go..... I thought Jamie said not all of the Xs had a shallow hole... but most did. Been a while..
« Reply #7 on: August 17, 2015, 06:29:44 PM »
Sorry for the delay in reply... Call me if you want, 703-675-5046 and I'll give you some thoughts... Computer is down and I'm slow to get to the library to get on line...
« Reply #8 on: August 19, 2015, 02:31:17 AM »
Thanks Jumper. It's going to be a few weeks out before I get to swinging this engine back toward the frame. The engine just got up on the mill table yesterday and fixtured tonight. It's bolted in solidly to the machine, the front cylinder is trammed to the spindle within half-a-thousandth and the first hole is indicated into center the same tolerance. When my 29/64ths endmill shows up, I'm going to start installing Time-serts. Glad that I took the extra hour to just pull the engine.
I was reluctant to pull the engine because I knew I'd start thinking about the rest of the internals. I know that I should do the transmission and install the scavenge pickup while I'm in this far. The thing is at face level. It ain't ever going to get easier than now. I'm just afraid of losing the momentum again. It's been in pieces for too long.
« Last Edit: August 20, 2015, 10:05:01 PM by Donkey Hotey »
« Reply #9 on: August 19, 2015, 09:22:56 AM »
Wow Greg, I'm impressed. It looks like you have all the right equipment. This ought to be one sweet running X when you're done with it.
« Reply #10 on: August 19, 2015, 08:54:26 PM »
You know ,  you might want to look into breaking it in half and balance that bad boy's  crank  ...just my 2 cents .....  very impressive work you are doing
« Reply #11 on: August 19, 2015, 10:17:26 PM »
Thanks Mike. Yes, it was a great running bike when it was still together. Its story is scattered around but, I had four other running motorcycles when I bought it and I only owned it four months before it blew the spark plug hole. In that short time, I piled a bit over 5,000 miles on it. If It had stayed running, I'd have worn it out by now. I've reasoned that the time it has spent in pieces, just added to the future riding I'd still be able to do with it.  :)
Yeah, no.  :) Weren't the 2000s supposed to have slightly different balancing anyway? I would prefer to not ever see either of my bikes crankshaft's out on the bench.
As for the work I'm doing, thank you. I'm pretty sure this is something like how Atlantic would do it. I'm just trying to stack the odds on the side of success...and sharing for future owners who have to tread this same path.
« Reply #12 on: August 23, 2015, 06:03:51 AM »
I can now say, with personal authority, that the two shallow cylinder stud holes were NOT a mistake at the factory and you CANNOT even afford to flat-bottom the holes to buy a few more threads.
I bought a 29/64ths endmill and my ONLY intent was to flat-bottom the existing V-bottom drill holes on two of the studs. When the mill came up and I went to blow the chips out of the hole, the masking tape on the rest of the engine openings ballooned up. Yes, it very slightly cut into an adjacent oil passage--my worst fear.
Since the passage ends up in the back of the scavenge pump, I'm going to assume it's a drain-back line from the cam boxes. Nonetheless, I prepared a ball of JB Weld, put it down the hole and packed it in lightly, before installing the Time-sert above it (no, the Time-sert was not actually touching the plug). Mickey mouse? Maybe. Nothing else could be done. I'll also RTV the stud before I install it, just in case the JB Weld ever leaks.
No, I didn't repeat this on the second shallow hole. All of the other holes measured 1.65" deep. All the inserts are done, tight and installed with red Loctite. They are as close to being part of the parent material as possible.
« Reply #13 on: August 23, 2015, 07:06:52 AM »
Oh greg how exasperating....
« Reply #14 on: August 23, 2015, 07:45:22 AM »
Hey Donkey (I feel like Shrek now) Thanks for sharing your experience here. Hope I never have to dive in that far but if I do it's nice to know you are leaving this trail of bread crumbs for me to find my way.
Frank
