Author Topic: overall drive ratio  (Read 3530 times)
overall drive ratio
« on: June 04, 2016, 03:44:35 PM »
Anyone off the top of their head know the sprocket tooth counts for the belt as well as the primary gear reduction ratio?  I see the owners handbook lists the transmission ratios but not the overall ratio.
I'm not convinced my Speedo is correct & I know the final overall ratio is close to 3.0:1 so I am asking the question
Re: overall drive ratio
« Reply #1 on: June 05, 2016, 06:44:52 AM »
I  don't know the ratio .
But I do know if your speedo hasn't been touched since built it's off.
Tim breidenbach used to have a calibration kit he'd loan out. Kind of pricey.as it wasn't getting borrowed much he sold it.
At a true 55, your X reads 60.
And from there it graduates less than 5 on slower speeds, and more respectively with speed.
« Reply #2 on: June 06, 2016, 08:52:38 AM »
I just mentally compensate myself. However, there has been some work and discussion on a plug-in electronic calibration device for our bikes. I know Sean Howard had come up with a little module, and was looking at producing a small number of adapters for our bikes. You might check with Jamie Jones at Atlantic EH, because if Sean produced them, Jamie would have them.
« Reply #3 on: June 11, 2016, 02:58:07 PM »
11% was the number tossed around in the early days.... If your going 90 MPH on an X... Enjoy the ride!!!
Hehehe..
« Reply #4 on: June 20, 2016, 08:50:18 PM »
I used GPS for speed & came up with 3.08.  I see however on superxparts that they sell a 32T sprocket, & they mention replaces orig 32T or your existing 30T.  My Speedo indication was off exactly this amount.  So.....it sounds as if our Speedo was set up for a 32T on front sprocket but most bikes had a 30T.  I need to count mine & see what I have for real.   if out belts go bad where do we get one?
« Reply #5 on: June 21, 2016, 06:28:33 AM »
Jamie/Marty at Atlantic EH have the belt...
