Author Topic: Fuel Pump-Fuel Injectors Cleaning/Repair  (Read 4705 times)
Offline Bigmax873
« on: March 07, 2017, 11:39:51 AM »
Hello Super-X community, I have inherited a beautiful 1999 Super-X from my deceased father; the bike has not ran in over 3 years and the fuel pump and fuel injectors could use a thorough cleaning/repair.
I am hoping for any advice on how to begin this task, the bike currently does not have the fuel pump operating and appears to be seized/not-functioning.  Advice on removing the fuel pump would be appreciated, as well as repair, any information on how I should begin this task would be much appreciated.
Thanks,
Max
Re: Fuel Pump-Fuel Injectors Cleaning/Repair
« Reply #1 on: March 07, 2017, 03:24:08 PM »
Max,
    as I don't know your skills, but you are asking.... that tells me you have at least some skills..
    So I'll treat this as such...
    Pull your gauge pod.... 2 !/2" bolts on top....   as you remove pod, you'll notice an electrical connector...  disconnect there...
    The tank will have a seat bolt under the seat, so remove that... and on the front of the tank will be 2 more 1/2 " bolts......
     lift the tank up from the rear, and set a piece of 1X or 2X piece of wood under the rear of the tank.... be sure to watch extra careful about the front of the tank hitting the triple tree and chipping the paint. I like to set a towel or rag in there just so I don't pinch....
     When tank is lifted... look underneath... on the left side will be a fuel line from the fuel pump to the fuel rail.... disconnect it.... I usually disconnect from fuel rail...
     Also on the left side is the wires for the fuel pump.... trace them out to the connector.... disconnect...
      On the left side there will also be the "over flow" pipe for the tank....   if you have everything disconnected, that pipe should just slide free when you lift the tank...
     On the right side is some wires for the sending unit...  same story...        Now you can lift the tank completely off...
     place tank upside down on a pile of shop towels or anything that will protect the surface....    The fuel pump will have a big snap ring.... remove that.... and then you can pull the pump...   dirty and crude? .... put a bolt in the threaded hole of the pump..... then grab your 1X and lay it on the edge of the pump mount so you can pry against it, with pliers pulling on that bolt..... it usually comes out easy enough...    there is a special tool for this, and many of us X owners have made one....  pliers, pry bar also work.
      Anything you want replaced you can get at superxparts.com       They have the fuel pumps in I believe now... and they should have "rebuilt" injectors for exchange on the shelf....
       Call Marty, she'll get you set up...
flatlandersupportingXworld
« Last Edit: March 07, 2017, 03:30:46 PM by wytfut »
Offline Bigmax873
« Reply #2 on: March 07, 2017, 05:38:21 PM »
Awesome thank you, I have the tank off, just have to rig my self a tool to get the pump out, as for the injectors, I was thinking about actually cleaning them myself as I heard that it was very uncommon for them to be beyond repair, is it worth putting the effort into cleaning them out or would I be better off just replacing them?
« Reply #3 on: March 07, 2017, 05:43:17 PM »
Soaking them or sprsying them will not clean them out. If you can figure out a way to have them fire off while cleaning them... Id just do the injector exchange...
« Reply #4 on: March 08, 2017, 07:01:56 PM »
Of course, if you happen to have an Ultra sonic cleaner in stock.....
 :o
