Author Topic: Lesson learned: Check stuff!  (Read 3779 times)
« on: May 30, 2017, 11:49:40 AM »
I rode #2016 to a track day event to get PR for ABATE yesterday morning.  On the way out, my bike started having a hard time idling.  I was almost to the track and she was running fine otherwise, so I decided to check into it when I got home.
Leaving the track, I got just a mile or two down the road and the engine started backfiring and bucking around.  I pulled over when it was safe and discovered that the coil had come off the plug on the front cylinder.  I snapped it back in place and all was well the rest of the trip and again today on my way to work.
I did have the coils off recently while replacing the upper valve cover gaskets and installing the safety wired screws for the lower valve cover, so it's possible I didn't snap the coil down all of the way.
A twin sure doesn't run well as a single.
Re: Lesson learned: Check stuff!
« Reply #1 on: June 04, 2017, 11:37:10 PM »
Ha, yea, that will do it. If (when) I break down the first thing that always comes to mind is the last thing I touched.
