Author Topic: Something Different  (Read 5758 times)
Something Different
« on: October 02, 2011, 03:44:20 PM »
Hey Bruce,
   I had been looking for a replacement headlamp bezel since mine was dented when I bought the bike. I found out that the Victory Vegas used the same headlamp nacelle. Victory wanted almost $150 just for the bezel. I found a complete Vegas headlamp assembly on eBay for $85 and promptly used the bezel from it. I then decided to install the composite headlamp that came with it to give my Super X a different look. Check it out, only a simple wire harness with H11 plugs on it is needed to make it work without cutting the stock wiring.
 <img src ="http://fp1.antelecom.net/kernev/NewHL1.JPG"><br>
<img src ="http://fp1.antelecom.net/kernev/NewHL2.JPG">
Re: Something Different
« Reply #1 on: October 02, 2011, 03:51:02 PM »
I'll try to attach the pictures directly...
« Reply #2 on: October 02, 2011, 03:58:45 PM »
very cool.... I had heard about the vegas bezels working.... lookes great.... I like that lamp.... it looks to be HID? ...
« Reply #3 on: October 02, 2011, 08:11:11 PM »
No, they are just standard headlamp bulbs. But I could install HID lamps in it. I would have to run heaver wire and a relay, however. It has enough light for my purposes, I doubt if I'll go HID.
« Reply #4 on: October 02, 2011, 08:32:46 PM »
well as hard as I try (you're apparently much better than I on this site.... I cannot get a picture of my X on here...
Just wanted to show you, I have a very similar reflector, with a clear flat lense, and only 1 bulb. I got it at "headwinds.com".... its not a HID either, but a big improvement over the OEM....
« Reply #5 on: October 03, 2011, 07:07:23 PM »
I did have trouble at first because the picture file was too big. If you have a program that allows you to resize your picture, or compress it in JPG format, you should be able to attach it. The picture can't be any larger than 250 KB or it won't attach.
« Reply #6 on: October 08, 2011, 07:50:27 AM »
Ah.... never mind the personal instructions then.... that was one of the windows that popped up when I tried to post a shot of my X..... I don't know of any programs on this giz box that will resize my pix for me.... thank you !!
